Hi all,
I'm a newbee to the sight but after countless hours of searching this forum, I rebuild my 06 1k. I still have a little more garage time left, but I'm running out of mods. Here's what I've done, any recommendations for power and handling???
Track time is in the plans as soon as we have a streak of good weather and I should have some pics after the test ride today if the rain holds out. BT002 aren't so good in the rain...
Bridgestone BT002 tires 120/70/17 and 190/55/17
Woodcraft strator cover with red double thick slide protection
Vortex black rearset
Galfer stainless steel front brake lines (silver)
Galfer stainless rear brake lines (red)
Galfer stainless steel clutch line red
Afam/Driven gearing 15/44 (red ano)
DID EVR3 gold chain
BMC race filters
Rapid Bike 3 with timing and custom mapping 184 hp to the rear wheel (160.5 at 6200ft)
PAIR mod
Velocity stacks (custom free mod)
Fiberglassed flapper mod
Jardine dual tip full carbon slip on
Heat wrapped headers and exhaust
Elka 3-way rear shock with hydraulic preload adjuster
EBC HH race pads front and rear
Lightened rear rotor (drilled out)
Engine Ice Coolant
HRC 1/6 throttle
GPR G4 stabilizer
Custom intake/air flow replacing horn
Speedo Healer
On-the-fly preload adjusters
Vortex gas cap (black) and base (red)
Rear swing arm blocks (red) chain adjuster
Radiator fan switch bypass and red LED lights on custom dash
Nicky Sprocket cover mod
Dan Kyle’s 20mm valve kit with springs for front fork
Also 29 cosmetic upgrades.
DID EVR3 gold chain
BMC race filters
PAIR mod
Engine Ice Coolant
HRC 1/6 throttle
GPR G4 stabilizer
Speedo Healer
