101 - 120 of 120 Posts
Discussion Starter #101
As posted in the original list
Rear bumper with turn signals, license plate holder and light (full assembly minus the license plate light connector, used for my aftermarket light wiring but wires are still there) $50 shipped
Discussion Starter #104
I'll take it.
I have a mail box in Blaine, Washington for shipping.
You can email me direct at "fjr AT ldrider.ca"
Sent you a PM on here. Tried to send an email but got an undeliverable response.
Discussion Starter #105
UPDATED LIST:
2015 Honda CBR1000rr non-ABS US model OEM parts, 1100 miles on bike when parts were removed
Make an offer for any parts you are interested in. Not looking to get rich just make it worth my effort to ship.
----- Rear spring (stock) spring only, no shock $30 shipped
-----Front and rear brake lines with banjo bolts $50 shipped
-----Black shift lever with rod and linkage has some scuffs but nothing major good toe pad $40 shipped
-----Brake master cylinder (has cheap aftermarket red lever) with reservoir and bracket (fully assembled as stock) $80 shipped
-----Clutch perch with cheap red lever $50
------Stock clutch cable $25 shipped
-----Rear brake light $30 shipped
-----Exhaust flapper servo motor with cable $30 shipped
-----Pair valve system (all hoses, plates, actuator, wires, etc.) $30 shipped
-----Throttle assembly with cable, has stock grip installed $50 shipped
-----front sprocket cover (minus metal support brace) $20 shipped
----Clip-ons (minus inner bar weights) $50 shipped
------Fuel tank locking cap (won't come with a key so you will either have to get the lock rekeyed for your key or I can make a copy of my key) $80 shipped
------Clear double bubble Windscreen $40 shipped
------Tank Side Covers with stomp grip pads installed $40 shipped
-----Dash side covers (inner air duct covers) minus rubber end seals $40 shipped
----- Seat cover (vinyl cover only, no foam or seat pan) not a wear mark, scratch, stain on it. Looks brand new! $40 shipped
-----Rear brake fluid reservoir $20 shipped
-------Radiator hose kit - ALL hoses, fittings, joints, and clamps. $50 shipped
ALL parts listed above are stock OEM parts , prices listed are just my guess feel free to make an offer
Aftermarket or other parts:
-----Driven Racing D-Axis Bar Ends Blue/Black (only installed for a few weeks) LIKE NEW! $40 shipped
-----T-Rex rear axle sliders BRAND NEW $40 shipped
-----Brembo RCS folding Brake lever (Black) standard length. has paint nick on end but otherwise good shape $30 shipped
-----Brembo MC fluid reservoir with bracket $25 shipped
-----used 2008 600rr rear shock linkage (Dogbone) with brackets $40 shipped. Bearings in good shape, no damage.
I can post more pictures of any of the parts, just let me know what you wanna see. They are all in like new condition
Discussion Starter #108
can you post a pic of the brembro brake lever and the brembro reservoir? Is there no Brembro master cylinder?
No master cylinder. I bought it used and changed the lever to a shorty and a driven racing reservoir so that's why I have the Brembo lever and reservoir with bracket.
20200313_110538.jpg small nick on end of lever 20200313_110546.jpg scuff marks on lever 20200313_110610.jpg
Discussion Starter #109
UPDATED LIST:
-----Rear fender $25 shipped
-----Brake master cylinder (NO LEVER) with reservoir and bracket (fully assembled as stock) $80 shipped
-----Throttle assembly with cable, has good stock grip installed $50 shipped
----Right side (throttle) Clip-on (minus inner bar weight) $30 shipped
Discussion Starter #111
got a few parts listed above (post #109) if anyone needs something
Discussion Starter #112
UPDATED LIST:
------Stock clutch cable $20 shipped
----- Seat cover (vinyl cover only, no foam or seat pan) not a wear mark, scratch, stain on it. Looks brand new! $30 shipped
RSC 2 finger clutch lever with perch and perch spacer. Black, has rash on very end of lever but other than that not a scratch. Works oerfect
$70 shipped
Discussion Starter #113
UPDATED LIST:
$70 shipped
Hello,
I am in need of several oem parts and wanted to see if you had them. Do you have right side clip on, throttle cables, right side crank case cover, right side foot brake lever, air intake panels, headlights or rear headlight cover? Thank you
I tried to send PM but couldnt seem to get website to work. I would like to purchase right side clipon, throttle assembly, Brembo RCS brake lever and intake tubes if still available.
Discussion Starter #116
Sent you a few PM's. I have the right clip on and throttle assembly with cables.
Have the "dash panels" or plastic covers that go over the inside of the intake tubes but do not have the air duct intake tubes themselves.
The Brembo brake lever is just the lever and not the master cylinder. Lever will only work with a Brembo MC.
Let me know what exactly you need and where they are being shipped and I'll give you a good package deal. Also have OEM windscreen and Driven racing bar ends if interested. Not sure how bad your damage is so not sure what you need
Discussion Starter #118
UPDATED LIST:
$70 shipped
