1 - 16 of 16 Posts
Discussion Starter #1 (Edited)
this might be a good sticky!
1091-34/100 is an example of a code you will find on an Ohlins shock spring. Using the below charts you can “decode” what you are looking at.
• The 1091 refers to the diameter and the length of the spring. Almost all Ohlins springs have a diameter of 57mm so that’s easy, the 1091 in this case means it has a 160mm length (when not on the shock)
• The -34 is the spring rate. For some unknown reason Ohlins uses it’s own numbers to label rate, but below on the rate conversion chart you can cross reference this number. In this case a -34 is a 100nm or 10.19kg or 571lb spring
• The /100 is the springs rate in Newton meters, but without the decimal. In this case the /100 means it’s a 100nm spring.
Art. nr. Rate
N/mm Kg/mm ibs/inch
-88 28 2.85 160
30 3.06 171
-90 32 3.26 183
-01 34 3.46 194
-02 36 3.67 206
-03 38 3.87 217
-04 40 4.08 228
-05 42 4.28 240
-06 44 4.48 251
-07 46 4.69 263
-08 48 4.89 274
-09 50 5.10 286
-10 52 5.30 297
-11 54 5.50 308
-12 56 5.71 320
-13 58 5.91 331
-14 60 6.11 343
-15 62 6.32 354
-16 64 6.52 365
-17 66 6.73 377
-18 68 6.93 388
-19 70 7.13 400
-21 75 7.64 428
-24 80 8.15 457
-26 85 8.66 485
-29 90 9.17 514
-31 95 9.68 542
-34 100 10.19 571
-36 105 10.70 600
-39 110 11.21 628
-41 115 11.72 657
-44 120 12.23 685
-49 130 13.25 742
-54 140 14.27 799
-59 150 15.29 857
-64 160 16.30 914
-69 170 17.32 971
-74 180 18.34 1028
-79 190 19.36 1085
-84 200 20.38 1142
-89 210 21.40 1199
Spring Length Chart
1093- 1091- 1092-
150 mm 160 mm 170 mm
5.9" 6.3" 6.7"
Discussion Starter #3
that is actuall 100n/mm. no decimal. 105, 110, 120 etc. the conversion is 10.19k/mm=100n/mm. -Joey
Thanks if i didn't have the flu at the moment i hopefully would have caught that.
Discussion Starter #5
Fireblade > CBR1000RR
Good reference information
I am bumping this thread because it took me awhile to find it, again. I lost the original Dan K. jpg and needed to check something.
Some folks might like to have this information.
I have a question about the chart that was posted.
Can any body tell me what the numbers mean within the chart.
i.e I have a 1091-29 spring. So that has a spring rate of 90N/mm and a length of 160mm but what does the number 78 in the grid refer to? Is that the price, $78 ?
Banned
Ohlins spring chart
Is there a Ohlin spring that fits on the 04/05 OEM forks? If so, what's the model number? Thanks in advance.
Banned
My head hurts, trying to understand all that stuff and that chart....
:signs053:
a d m i n
Added DK’s foto to the first post..
Is this thread still relevant?
1 - 16 of 16 Posts
