1 - 4 of 4 Posts
crotch rocket
I'm having problems getting to the connectors. The instructions kind of suck at this point. It simply says to rotate the fuel tank upwards & hold in position--doesn't even say to remove any tank bolts first.
I removed the two tank bolts (one on each side of the main part of the tank) & rotated the top of the tank up & back, but it only goes up about 5 inches. The tank still completely blocks access to the lower fuel injectors & throttle position sensor. It appears to be pulling on at least one hose that goes down the left rear side of the engine.
Am I missing something? Do I just need to yank it up harder? I'd obviously prefer not to break anything relating to the fuel lines.
crotch rocket
Discussion Starter · #2 ·
I figured it out--went back & gave it more of a firm pull, & the tank moved up & out of the way.
Now I just need an exhaust....
1 - 4 of 4 Posts
