Alright...so to vent, this bike is really starting to annoy. Bought it brand new, 0 miles, and so far it's given me more problems than the '06 I sold for it.
I've searched and found multiple threads regarding this, but I'm specifically looking for any quick info on where the battery terminals run to?
Basically, my bike starts right up every day if the engine is cold. But once I ride, even if it's a mile or two down the street to fill it up with gas, when I try to start it back up, 9 times out of 10 it just cranks and cranks, but it won't turn over.
What makes my situation a bit different than other threads I've read is that my gauges literally flash on and off when it's cranking, as if the battery terminals are loose. But my terminals are quite snug and clean. I'm really hoping there is just a loose connection somewhere, but I'm not even sure where the cables route to on this bike.
For T/S purposes, I just took the following readings at the battery:
-Bike off, key in 'off' position: 12.81V
-Bike off, key in 'run' position: 12.46V
-Cranking: Lowest I saw was 10.6V
-Running: 14.34V
I understand that resistance can build up in electrical components as they heat up...so I guess where would you start looking? The bike now has a bit over 8k miles. I don't see how anything could be failing already...stator, plugs, battery. I know it's in the realm of possibility, but again, the bike starts without any issue when it's cold. I really hope I don't have to start testing every freaking sensor.
As always, any feedback is greatly appreciated.
Shaun
-Running: 14.34V
Shaun
