I recently replaced my fork seals and they are no longer leaking. However, I did NOT replace the copper sealing washers at the bottom of the fork leg (attached to the allen bolt that holds the damper assembly) and the one side is leaking.
My question: can I replace the copper washers with the forks upside down so I don't lose oil?
I'm afraid since the fork will be upside down, the damper rod will fall away from the bottom of the fork because the bolt isn't there to hold it.
But then again wouldn't the spring hold the damper to the bottom of the fork?
Also, would the damper spin and not allow the bolt to tighten? Or would the spring keep enough pressure on it that it won't spin?
When I replaced the fork seals, one washer was loose but the other was stuck to the underside of the bolt head. So maybe I won't be able to separate the washer from the bolt?
And if I'm remembering correctly, the bolts were difficult to get the threads started, or maybe the damper was spinning and I didn't realize it?
Many things to consider. I'm afraid to take this on if it's going to end up being a nightmare. If anyone has done this or has any insight, please let me know!!
