1 - 5 of 5 Posts
I just got a 2006 cbr1krr with only 6000 miles on it. As soon as I got home I lost the rear brakes and a spring fell out. I'm not sure where the spring goes but i know it's important because when I press the pedal nothing happens. Is this a common issue or does anyone know where the spring might go? It is a very short spring with a hook on both ends.
It's the spring that returns the pedal back to original position after you press the brake. Clips on tab on bottom of pedal and attached to the main rear set. You will have to unbolt the rear set and have a look it's very easy to fix. You will see on the pedal were the spring goes.
1 - 5 of 5 Posts
