Thanks for keeping us updated.
I am in same situation. But received a different document, jjust saying it need to be updated....
Any word from Brentune on whether the Stage 1 clears this?Received a recall for the CBR1000RR-R (SP) today. Living in the Netherlands so not sure if this covers all bikes EU+ROW. It's in dutch but essentially it says:
Due to an error in the ODB program creates incorrect settings in the PGM F1 CPU, which in turn triggers increased process times in the PGM-ECM and invokes a reset. This could result in fuel and ignition stopping functioning and the bike stalling.
This never happened to the bike, nor have I read it here happening to others. Since I am running the Brentune stage 1 tune I am not sure if this problem is "cleansed" with the new map. I'll be checking that with Motobull / Brentune.
Regards, Danny
hi dont do it, it only applies to 0-4500 closed loop fuel injection function, especially if you have a BT tune, they disable closed loop anyway,Received a recall for the CBR1000RR-R (SP) today. Living in the Netherlands so not sure if this covers all bikes EU+ROW. It's in dutch but essentially it says:
Regards, Danny
My bike hasn’t been remapped, but interested to know what you removed, was it just software or any physical modification.You have the high idle after the ODB PGM update?
If that's the case, that could explain why my idle also increased to around 1600rpm after installing BT Moto Stage 2 map. From what I understood, the fix was added to Stage 2. Honda states idle should 1400rpm +/-100rpm. I think with the BT Moto stage 2 it's at least 1600rpm +/-250.
At first, I was thinking an air leak was the cause. To rule that out I returned to Stage 1 and the rpm decreased to 1400 +/-100.
