Alrighty, so about a month ago I installed a motion pro Rev2 throttle on my 07 Blade. It came with motion pro road control grips. Usually I use a grip glue that is like a contact adhesive. But this time I used pro taper grip glue, which if any of you are familiar, is just basically cyanoacrylate super glue. Now, a little over a month, or ~3000 miles, later I noticed a few spots of the motion pro grips wearing through. Especially where my thumb sits. All of the texture is gone and even a little past that. Im not really complaining, all the really soft/sticky grips I’ve ever used were kind of delicate. Im just wondering what would be the best method to remove the old grip from the throttle tube without damaging it. Should I just leave the glue residue and put a new grip over that, or sand the residue down smooth with fine grit sandpaper, or just buy a replacement throttle tube… I’d like to reuse it if I can, but this pro taper glue is all but impervious to solvents.
