1 - 4 of 4 Posts
· Registered
Good morning all
As I mentioned in my previous posts I have completely rebuilt a beautiful 2004 CBR1000RR. The past 2 weeks I finally had sometime to ride it and I noticed a very very strange issue with the coolant temperature
When I'm just using the dipped beam, I get a reading of temperature, example 109°C (when in traffic). When I switch on the full high beam the reading shows around 5-7°C higher, example 115°C. If I turn off full beam it goes back to 109°C
The gauge cluster is aftermarket not OEM, but I kinda ruled that out as a guy on facebook has a similar problem with the OEM cluster
I'm guessing it's a ground issue. But which ground should I tackle? I will probabluly start with the ground wires that are fixed to the frame, give them a good clean and see what happens
Since I couldn't upload a video, I took pictures with high beam off and on, each given 5 seconds intervals
Anyone else had a similar issue?
Thanks in advance
Speedometer Odometer Gauge Tachometer Motor vehicle
Speedometer Trip computer Odometer Light Motor vehicle
Speedometer Odometer Light Motor vehicle Gauge
Speedometer Odometer Vehicle Trip computer Motor vehicle
Speedometer Odometer Motor vehicle Tachometer Trip computer
Speedometer Odometer Trip computer Vehicle Gauge
Sent from my 21081111RG using Tapatalk
· Tech SuperMod!
The temperature sensor output varies by the supply voltage. When you turn on the high beam, you draw 5A more current from the battery and that causes the reading to change because the battery voltage goes down.
Does it do this with the bike running? What type of battery are you using?
· Registered
The bike was off when I did the testing. However, I have ridden the bike with the high beam on and noticed the temp being higher than normal, and it was the first time I went for a ride with high beams on
Battery is a brand new Motobatt, never had issues with Motobatts
· Registered
Discussion Starter · #4 ·
I forgot to mention that I have a full Akrapovic Evo Ti exhaust and a PC3. Quite possibly it's running on the hot side as it's lean on idle (didn't mess with the fueling yet) and the Akra headers do sit super close to the radiator, so quite possibly could be the reason
The coolant doesn't boil or piss out the overflow tank like many others mention when their Blade overheats, so I don't think it's that big of a deal
It is also safe to say that the head gasket is still intact as the oil is still clear and no smoke coming out the exhaust
The only thing that annoys me is the fan comes on at 115°C and it does not allow it to rise anymore. Once I get moving, it drops down instantly
Rectangle Wood Font Tints and shades Art
1 - 4 of 4 Posts
