were in canada are you? just word of advice with the brembo clutch lever and older be very care full with brembo switch on the clutch! if it doesn't make very good contact with perch it will cause all sorts of problems
I got the flanged Ti nuts and Ti studs for the sprocket - no need for washers. Saves about 7 grams LOL
Get the TSR silver bar ends, really makes the stock bars pop.
Do you guys run that stock plastic chain guard? Noticed it's not there in the picture. I leave mine on there to keep the chain crud off the bodywork but I'm always thinking of taking it off and going without.
Is that the carbon swingarm cover, rear hugger, chain guard combo one?I do keep mine on. I had it off and had not put it back on. I have a carbon one on its way
Well, you have to do something to make up for the extra weight of that RCV sock thing..I do keep mine on. I had it off and had not put it back on. I have a carbon one on its way
TSR have a cool carbon fender that can offset that weightWell, you have to do something to make up for the extra weight of that RCV sock thing..
Looking good!
Did you take this chance to replace the Hondabond with gaskets?
