141 - 160 of 201 Posts
At least you get replies from Pro Bolt, I have asked for the dimensions/bolts for brake caliper x 3 each and the pinch bolts along with rear brake for the SP1.
Probolts AU x 2 emails in past month and nothing. Can you confirm for me then please?
2018 CBR1000RR SP
Discussion Starter #142
I had done my research and found out for myself. Using part fiches to confirm what the size of the bolts are. I also found the 17-19 CBR and the 08-16 CBR have a lot of the same bolts. Probolt has more listed for the 08-16 CBR, so I’m always browsing through that. But Honda used a lot of the same bolts over the years. There are special pieces on the 08-16 CBR that have been carried over to the 17-19 CBR, that Probolt hasn’t listed for the 17-19 CBR.
I bought the business card size tool pro bolt has. Then I use the tool to find out what diameter, length, and pitch is needed.
Start with the parts fiches, or start removing bolts and measuring them.
@Rusa, Hey man, I’m wondering whats mounted on your headlights? How bad does it reduce visibility, day/night?
Can you post a link or manufacturer? Thanks.
2018 CBR1000RR SP
Discussion Starter #153
I’m not to sure what part you are talking about.
So I thought you had a dark lens covering the upper half of your headlights, kind of like the mods that jeep drivers do. Guess this is an idea..
Yeah for sure nothing wrong with doing a film kit over the headlight, will keep you posted as i will do either very light yellow.. more to protect the headlight than anything else.
2018 CBR1000RR SP
Discussion Starter #156
TST Fe and Custom LED integrated tail are on there way
I got the custom led in my sc77 and sc59. I love it, super bright. On our sc77, you don’t need the relay, blinkers work perfectly. As far as the Fe, I went with NRC tucked. Awesome thread bro.
2018 CBR1000RR SP
Discussion Starter #158
Carbomoto showing me the process of my new subframe
