Actually the stock setup is a single line split at the fender .
The two line kits work great but if you HAVE to keep it like stock or similar .Galfer makes a gp brake kit (single off the master and splits the calipers).
Actually the stock setup is a single line split at the fender .Hey guys, I want to change out the front brake lines but i can only find a 2lin kit. I would like to keep the stock setup which is 3 lines what do i do or where can i find the kit I want, Black on Black....????
Stock set up is a 3 line kit. Single line would be just 1 brake line. Galfer GP is the exact same setup as stock only the lines are routed in front of the forks, however they can customize your kit to be routed just like the stock lines.Actually the stock setup is a single line split at the fender .
