1 - 9 of 9 Posts
So I crashed my SC77 SP1 a month ago. Waiting for Ohlins parts then the forks will be sorted. Fixed all the rest myself. (Alternator cover, numerous fairings).
When I start the bike it does not smoke, but then after about 20 sec it starts smoking like crazy (white smoke).
No error codes apart from the forks being off for repair.
Any ideas on where it can be sucking in oil and/or coolant? (appreciate all the assistance)
Hook 'em!
2017 CBR1000S1
Do you have any pictures of the damage before you made repairs?
Yeah, it just looks like a brand new S77 LOL :)
I figured out what the problem was, because the bike sort of went upside down during the slide some oil went past the crankcase breather into the exhaust. There is about 100ml if oil in the bottom of the CAT. Will start it up and let you know. Thanks for reading my post and commenting, appreciate it.
262344
Discussion Starter · #4 ·
Ok so I started it again today, after 40 seconds it starts smoking like crazy. Feel sorry for the neighborhood so I killed it. Will be taking the exhaust of entirely so that I can see if the smoke comes from the valve side - will only idle it for a few seconds like this.
BOTM Moderator
Post a video.
The 40 seconds is interesting. That would support there being oil in the exhaust. The exhaust is not hot enough to burn the oil when you first start it cold. Have you drained the engine oil and refilled it with new oil and filter?
Discussion Starter · #7 · (Edited)
Video will follow shortly. Yes I drained the oil, as I thought if it was stuck somewhere it should not be after the drain. Will start again today and pollute a little.
2015 Honda CBR 1000rr non ABS
Same thing happens to every bike I've seen lay on its side for a few minutes or tip over.
Mine had oil in the air box after my lowside. I cleaned it out and it still smoked A few minutes and cleared up.
Nothing to worry about
1 - 9 of 9 Posts
