Hello All Again!
As the title suggests, I'm looking for any and all owners to chime in here. My rear brake drag seems to be worse than I believe it should be, as my rear wheel is filthy after every ride. I'm looking to see how badly your guys' rear brakes drag and how much dusting you get on your rim.
As a reference example - I washed my bike, rims were spotless. I removed my rear brake pads and scrubbed them with a brillo pad, then cleaned them with brake cleaner. I also used the brake cleaner and rags on the rear rotor, spraying and wiping until the rag was completely clean after a wipe. Did this on both sides of the rotor.
Put everything back together, went on a ride that was less than SIX miles, and did not touch the rear brake once.
Photos below: I did not wipe the entire rim, maybe a quarter of the surface area on each towel, just to get a sample. First photo is from the chain side, 2nd is from the caliper side. These are the OEM pads.
Again this amount of dusting, in just a few miles, is without even using the rear brakes. All of the dust is from the drag. Am I crazy...? This can't be normal?
As for the front...this bike is the complete opposite of all bikes I've ever owned to this day, as the front wheel has ZERO brake drag. The front wheel spins freely, no sound of rubbing whatsoever.
Shaun
Shaun
