The new bolts will stretch at first. You can use the old or new bolts for measurements. I'd use the new bolts for final assembly. Put some Lucas assembly lube or something similar on the threads. Repeated torqueing of aluminum case threads is bad. Keep them lubed up to prevent tearing them up. Studs are the way to go if you want to spend some more money.
I'll try to remember to take a picture of the torque procedure in the book but you should find a factory service manual if you haven't already.
Buy this
Buy this
