1 - 3 of 3 Posts
Just picked up a new 2017 SP. I have not owned a fully electronic suspension before. The owners manual does not address setting sag. Is this done electronically via the suspension settings or is this done manually? If you have any info on setting sag on this electronic suspension , please advise. Thank you!
Hi-
My CBR is the older one. I don't have experience with your bike but I did have the R1M w electric suspension similar to the Honda setup.
On that bike the preload was still done mechanically, for the fork it required carefully disconnecting the leads into the fork caps and using a wrench like normal. Shock was via typical threaded preload collar arrangement.
Hope that is somewhat helpful, I'm a little surprised the manual doesn't address it.
1 - 3 of 3 Posts
