sitting 4-5yrs
268 Views 3 Replies 4 Participants Last post by  John Harris
I havent ridden my bike in years and curious wat I should do to get her back on the road, would a full service do or does it need more, she was started less then 12mths ago. Can I just change fluids or, nah. I am interested in what youse have to say and would be gratefull for any input you have, I think I know what I should do but maybe I just need to be told
1 - 4 of 4 Posts
Yeah, change all fluids. Don't forget brakes and blinker fluid.
Also dump out tank and put in fresh petrol with some PEA-based fuel-system cleaner. EFI systems have sealed tanks, so it doesn't degrade as quickly as carby bikes with vented tanks.
Measure battery, if it drops below 11v when cranking, you'll need new one.
Reactions: 1
Carefully inspect tires and should replace if more than 2-3 years old.
I would personally disassemble and flush out all the fuel lines, clean the injectors, and run the fuel pump with some fresh gas in the tank and discard a cup of fuel that comes out.
Inspect fork seals for oil leak as that tends to creep up on people after long storage times and ruins the brakes when you ride it.
Reactions: 1
I concur. Drain, bleed, flush anything with liquids. If the tires need it and if you have rubber valve stems then replace them with the 90 degree aluminum ones. Had old stems crack and leak so cheap insurance to replace.
Reactions: 1
1 - 4 of 4 Posts
