1 - 20 of 136 Posts
SV Racer
2004 CBR1000RR (49-state)
JH2SC570*4M000023 thru JH2SC570*4M006812
2004 CBR1000RR (CA)
JH2SC571*4M000016 thru JH2SC571*4M001407
2005 CBR1000RR (49-state)
JH2SC570*5M100007 thru JH2SC570*5M104196
2005 CBR1000RR (49-state Repsol)
JH2SC574*5M100001 thru JH2SC574*5M101509
2005 CBR1000RR (CA)
JH2SC571*5M100001 thru JH2SC571*5M101334
2005 CBR1000RR (CA Repsol)
JH2SC575*5M100001 thru JH2SC575*5M100522
American Honda has determined that the
ACG/charging system (stator and flywheel) on
affected 2004-2005 CBR1000RR models may
overheat and cause a short circuit, resulting in
insufficient battery charging.
To ensure customer satisfaction, American
Honda is extending the warranty an additional
six years for the ACG only.
If a customer complains that the battery of
their 2004-2005 CBR1000RR is not recharging
properly, proceed to the INSPECTION section
of this Service Bulletin.
All 2004-2005 CBR1000RR customers within
the affected VIN range will receive a letter
notifying them of the extended warranty. If
the ACG is malfunctioning, they should take
their motorcycle to a Honda motorcycle
dealer to have the ACG inspected and, if necessary,
replaced.
A copy of the customer letter is reproduced
on page four of this Service Bulletin.
Before you begin the repair procedure, check
to see if the unit has already been repaired.
• If there is a punch mark below the first letter
of the VIN, the unit has been repaired. If
the customer complains of a charging
problem, proceed with normal troubleshooting.
• If there is no punch mark below the first
letter of the VIN, the unit has not been
repaired. Proceed to the INSPECTION section
NOTE: This is a warranty extension, NOT a
product update. It is your responsibility to
make sure the VIN is within the seven year
period of the unit’s purchase and delivery
date to the customer.
INSPECTION
1. Remove the left middle cowl (refer to section
3-8 of the 2004-2007 CBR1000RR Service
Manual).
2. Remove the wire band, and disconnect the
alternator 3P (natural color) connector.
3. Check each yellow terminal (of the
alternator side connector) to ground.
There should be no continuity.
Also, check the resistance between the three
yellow terminals using a circuit tester.
Standard: 0.1 – 1.0 ohm (at 20° / 68° F)
• If there is no continuity to ground on any
of the three yellow terminals and the resistance
is within specification, there may be
another problem. Proceed with normal
troubleshooting.
• If there is continuity to ground on any of
the three yellow terminals, or the resistance
is not within specification, replace
the ACG with the countermeasure parts
kit. Go to the REPAIR PROCEDURE and
PARTS INFORMATION sections of this
Service Bulletin.
REPAIR PROCEDURE
To replace the ACG, refer to section 11 of the
2004-2007 CBR1000RR Service Manual.
IDENTIFICATION
After you have completed the repair, place a
punch mark below the first letter of the
VIN, which is located on the right side of the
steering head pipe.
PARTS INFORMATION
REQUIRED PARTS:
ACG SET
P/N: 06311-MEL-305
H/C: 8700213
The set includes the following parts:
Flywheel Comp.
Stator Comp.
WARRANTY INFORMATION
Normal warranty claim submission requirements
apply. After completing the repair, submit
one warranty claim per unit with the
following information:
WARRANTY CLAIM TEMPLATE:
2004-2005 CBR1000RR Stator Warranty
Extension
Template: Q47A
Flat Rate Time: 1.2 hours
TEXT OF CUSTOMER LETTER
May 2007
Dear CBR1000RR Owner:
American Honda has determined that riding a 2004-2005 CBR1000RR motorcycle in the low rpm range for an
extended period of time may cause the ACG to overheat, which causes a short circuit of the stator windings,
resulting in insufficient battery charging.
Warranty Extension
To ensure long-term satisfaction with your Honda, American Honda is providing a six-year warranty extension
for the ACG (charging system) on 2004-2005 Honda CBR1000RR motorcycles. This is in addition to the standard
one-year warranty that comes with your CBR1000RR. Please note that this Warranty Extension does not
apply to any CBR1000RR that has had its electrical system modified, aftermarket electrical accessories installed,
or accident damage.
What should you do?
If your CBR1000RR is starting normally, you do not need to do anything at this time.
If, however, your 2004-2005 CBR1000RR is becoming increasingly difficult to start (such as after refueling during
a ride), because the engine cranks slowly or will not crank at all, the battery may have discharged while riding
due to a faulty ACG. (Note: This warranty extension does not apply to starting problems that result from
improper battery storage or any other electrical system malfunction.)
If you believe your 2004-2005 CBR1000RR is showing signs of a faulty ACG, please call any authorized Honda
motorcycle dealer and make an appointment to have your motorcycle inspected and, if necessary, repaired.
Although the repair will take less than three hours, please plan to leave your CBR1000RR for a day to allow the
dealer flexibility in scheduling.
If you previously paid for a repair for this problem, you may be eligible for reimbursement. Please complete and
mail the enclosed Request for Reimbursement Form.
Who to contact if you experience problems.
If you are not satisfied with the service you receive from your Honda dealer, you may write or call:
American Honda Motor Co., Inc.
Motorcycle Customer Support
Mail Stop 100-4C-7B
1919 Torrance Blvd.
Torrance, CA 90501-2746
(866) 784-1870
What to do if you feel this notice is in error.
This notice was mailed to you according to the most current information we have available. If you no longer own
this vehicle, or some information in this notice is incorrect, please fill out and return the included, postage-paid
Information Change Card. This will help us update our records.
If you have questions.
If you have questions about this notice, or need assistance with contacting a Honda dealer, please call Motorcycle
Customer Support at (866) 784-1870.
We apologize for any inconvenience this may cause you. Thank you for your CBR1000RR purchase and your
cooperation.
Sincerely,
Motorcycle Division
TEXT OF CUSTOMER LETTER REIMBURSEMENT FORM
If you have previously paid for this repair.
Request For Reimbursement
2004-2005 CBR1000RR ACG Warranty Extension
If you meet the following qualifications, American Honda Motor Co., Inc. will reimburse you for the
cost of ACG replacement. No reimbursement will be made for other costs or repairs.
1. The vehicle must be a 2004-2005 CBR1000RR.
2. The previous ACG replacement must have occurred before May 18, 2007.
3. You must have a repair bill showing itemized parts and labor costs, CBR1000RR model, year,
VIN, name, address and phone number of the repair shop, and the date of the repair. The ACG
must have been replaced due to a low output condition. There must be verification of
payment, such as a copy of a cancelled check, cash receipt, or paid invoice.
4. To qualify for reimbursement, it is not necessary that you still own the affected 2004-2005
CBR1000RR, but you must have been the owner when the ACG was replaced. Only the owner
at the time of repair may request reimbursement. Do not request reimbursement for the
expenses of any other owner.
IF YOU ARE QUALIFIED FOR REIMBURSEMENT:
Fill in the blanks; please print clearly.
Street Address: ______________________________________________________________
City: _________________________________________________________ State: _________
Telephone: ________________________________
Vehicle Identification Number (VIN) ___________________________________________
Total Amount Requested _____________________________________________________
Mail this form together with a copy of your repair bill and verification of payment to:
Customer Support, M/S 100-4C-7B
1919 Torrance Blvd.
Please allow 6–8 weeks for reimbursement processing.
This form is provided for dealer information and customer photocopies if needed.
Connect the dots
Wow..this is like a year late..Sucks that for those of us who just bought new stators it doesn't look like we qualify.
Honda is way ahead of you. If you check the part number you will find that it is the same.
yeah but they said that they wont cover me since i changed up my lights and added a pc3 and what not. also added an aftermarket stator thinkin that it would fix the problem. so for those not covered, like myself, just get an '06 stator on ebay and you will be fine. didnt even need to upgrade my flywheel
SV Racer
Discussion Starter #9
You got the dealer's answer, not Honda's answer. Contact Customer Service yourself.
no, i got hondas answer from them...never called the dealer homie. called the number that was on the letter they sent me and they said a big fat no. if you know a way around it i sure as hell would like to know tho cause i really dont wanna have to put in a new stator once a year. there havent been any problems yet but that doesnt mean that there wont be ya know.
06/07 stator problem too
Hi there. Just would like to get more info if you guys know of any problem related to the 06/07 stator. My stator coil got burned just after 8mths of riding my new 2007 model, ard 14000km. Is the coil of any difference compared to the 04/05 model. What's the likely cause? I usually ride at mid- to-high rev so it couldn't be due to the repetitive low rev riding issue. This makes me loose trust in honda sportbikes due to this issue.....unreliable!!! You just can't have a peace of mind during a long trip not knowing when the stator coil will cook up again.
Pls help to enlighten me or better still reassure me. I'm residing in Singapore and i believe a lot of the 06/07 riders here would like to know.
Wow, you guys over in US are lucky to get your stator replaced by Honda. Here in Thailand there is not even an authorized Honda dealer for big bikes. So i guess i'll be paying my new stator myself.
mine went at 20,000 kms then at 40,000 kms (both covered under warranty). Bike has had plenty of aftermarket parts, but both dealers I deal with had no issue with replacing rotor/stator and reg/rec fre of charge.... Bikes now 2 1/2 years old now and just over 50,000 kms, so am anticipating it going again at about 60,000 kms... Have already warned the bike shop I'll be back at about 60k, expecting them to replace the system again.....
This is all back in Sydney Australia
Hey Guys
I'm based in Ireland & I think I may have this problem?? Thought it was a poor battery & fitted a new one. Now it's dead too!! My bike is a 2004 CBR1000rr model. Can anyone confirm that this problem is not specific to the States?? is this a problem for European 1000rr's too??
Many Thanks
DymagBlade
Ireland
Hey Guys
Many Thanks
DymagBlade
Ireland
it sounds like a bad stator to me. buy a trickle charger for the battery's, you may be able to save them still. i dont know if it is just for the states or not, but your problem def sounds like the stator is gone. if your not covered for some reason under any warranty then do like i did and find a barely used '06 stator and put it in. should work fine, but im not exactly and expert on these things. but i can say that i havent had a problem since on my bike.
1 - 20 of 136 Posts
