1 - 20 of 198 Posts
· Registered
Letting the build start .. will be posting on Instagram as well and documenting build
mine ( vin# 41 ) got delivered to the dealer today -- get her on Saturday
the truck driver is happy because I called the hitman off :)
plans are ( with many parts gathered already )
1. Akra full titanium exhaust
2. Dynojet pv5
3. Yosh fender eliminator
4. Brembo mc rcs19
5. Ceramic wheel bearings
6. Graves smog block off plates
7. Akra carbon exhaust bracket
8. Swingarm spools
9. SP2 seat cover
10. CNC billet fuel gas cap
11. Engine cover stator crash pad sliders
12. BMC air filter
13. Honda healtech exhaust servo eliminator
14. Honda cbr 1000rr fork spindle by evotech
15. Puig double bubble clear windscreen ( might get HRC windscreen )
16. Stainless steel brake lines
17. H20 Radiator
18. Samco hoses
in progress ..
19. HRC Kit camshafts ( intake and exhaust )
20. HRC Camshaft sprockets + bolts + cam caps
21. HRC Valve Springs ( intake and exhaust )
22. Head work ( Livengood / Ten Kate / other )
23. HRC velocity stacks / funnels
24. Ken Tate carbon fiber air intakes
25. Hard bodies race body work
26. Ken Tate ECU reflash or other reflash
pics coming soon .. also set to be on Instagram ... will share info soon ( video, pics, etc ) .. pulling motor w/in next 2 weeks and pulling off head ..
· Premium Member
What’s the purpose of flashing the ECU & doing PC5?
Flashing will remove the restrictions written into the ECU's code from the factory. For example, the throttle bodies closing at high RPM to pass noise & emission requirements. Once these restrictions are removed, the PC5 (or Bazzazz, Rapid Bike) will tune for optimal air/fuel at all RPMs.
· Premium Member
This can be done in the ECU.
· Registered
Discussion Starter · #10 · (Edited)
more pics from the dealer today ...
ceramic wheel bearings installed
ceramic wheel bearing part numbers -- you probably can call world wide bearings direct, not sure which is for the front and rear --
B130066 - get 2
B130092 - get 2
if you care to replace the OEL seals
91251-MKF-D41 - get 1
91253-MFL-003 - get 2
91252-MKF-D41 - get 1
· Registered
Discussion Starter · #11 · (Edited)
Partial list ( still tracking HRC items down )
healtech servo eliminator
graves smog plates
SP2 seat cover
Front fork sliders
PC5
Brembo MC RS19
quick change gas cap
swingarm spools
Akra carbon exhaust hanger
BMC air filter
PUIG windscreen
frame sliders -- when I thought the case covers were gold :(
akra ti exhaust
H20 Performance Radiator and hose w/hose clamps
this is what the rad is supposed to look like
I still have a long way to go, but not bad for a bike that I don't even own yet ( till this weekend :) -- all the HRC engine goodies at next and some Ken Tate items ...
· Registered
Discussion Starter · #16 ·
fyi -per RC45 .. bearing sizes are
6005 front wheel bearings
60/28 rear wheel bearings
31X63X16 sprocket carrier bearing
World Wide Bearing direct contact info:
1-800-575-3220
.. I just realized that the P/N I provided is what was in the dealer system ..they may track it differently ...
· Banned
Would you be at all willing to look into the service manual to see where the plug is on the 2017 for crossing to reset check engine? Would beyond appreciate it.
070PZ-ZY30100 & 07ZAJ-RDJA110 I believe are the parts
But do we have to use a jump plug? There is a CEL display menu in the Mechanics view, can't the CELs be reset from in the menu?
1 - 20 of 198 Posts
