1 - 1 of 1 Posts
Site Sponsors
Check out the line of EVO 2.0 electric tank bags by SW-Motech available in a range of sizes and shapes. They are all compatible with the company's proprietary quick-disconnect tank rings. Their electric version provides power from the bike’s electrical system to keep the devices in your bag charged. The circuit is complete only when the bag is attached to the ring. The locking system on top of the ring allows you to snap the bag into place and keeps it securely attached at all times until you pull a release cable to take it off.
SW-Motech is a German motorcycle accessory manufacturer that has been in the business since 1999. The company uses advanced technologies and modern materials to produce durable and reliable parts and accessories for a wide range of bikes and applications. SW-Motech tank bags are made of rugged, water-resistant ballistic nylon and have a variety of smart details like convenient zippered pockets, mesh compartments, shoulder straps and handles, volume-expanding design, reflective elements, D-rings, interior partition, and more.
SW-Motech® - EVO 2.0 GS Electric Tank Bag
Specifications:
EVO GS tank bag:
• Material: 1680D Ballistic Nylon / 1680D Ballistic Nylon
• Color: Black / grey
• Size: 31,0 x 25,0 x 41,0 cm / 12.2 x 9.8 x 16.1 in
• Weight: 2,1 kg / 4.6 lb
• Total Volume: 16,0-22,0 l
EVO 2.0 Electric top ring:
• Color: Black / red
• Weight: 0,7 kg / 1.5 lb
Features:
• The EVO 2.0 electric top ring is screwed to the EVO tank bag instead of the standard top ring
• The EVO 2.0 electric kit can be used for any EVO tank ring
• The circuit is closed by snapping the top ring on the tank ring; the circuit is disconnected when unlocking the top ring
• Operating current maximum 5 amps
• Direct connection to the vehicle battery
• Fuse in the cable harness (5 A)
• Vibration-resistant mounted, gold-plated spring contacts
• Waterproof plug connection between cable harness and power contact
EVO GS tank bag:
• Inner storage with mesh compartment
• Zipper to expand the volume
• 3 outer pockets
• 2 cable feed-throughs
• Durable carrying handle and shoulder strap
• Connectors for GPS mount, map holder, smartphone or tablet drybag
• The patented EVO tank ring provides a secure hold for EVO tank bags and allows you to lock and remove them with a single movement
• Pull strap for releasing the QUICK-LOCK mechanism is secured with a snap fastener
• Can be used with a cable lock or anti-theft protection
• Individual mounting of the upper ring for best fit
• Reflective details for better visibility
• Weather protection with the supplied rain cover
• High form stability due to EVA plastic base and padding
• Made from durable, highly UV-resistant 1680D ballistic nylon with water-resistant interior coating
SW-Motech® - EVO 2.0 Trial Electric Tank Bag
Specifications:
EVO Trial Electric Tank Bag:
• Size: 33,0 x 19,0 x 38,0 cm / 13.0 x 7.5 x 15.0 in
• Weight: 1,9 kg / 4.2 lb
• Total Volume: 15,0-22,0 l
Features:
• EVO Trial tank bag:
• Integrated map holder that also supports touch function on digital devices
• 2 outer pockets
• Fits GPS mount, map holder, smartphone or tablet dry bag
SW-Motech® - Street Rack Adapter For EVO Tank Bag
Features:
• Material: Fiberglass-reinforced polyamide
• Color: Black
• Weight: 0,2 kg / 0.3 lb
• For securing EVO tank bags on the adapter plate for STREET-RACK
• QUICK-LOCK function makes simple snapping on of the following tank bag models possible: EVO Micro, EVO Daypack, EVO Sport and if need be EVO Engage
• Easy assembly: EVO tank ring is screwed onto the adapter plate
Click on the image to enter the product page at MOTORCYCLEiD.com for more information.
To browse the full catalog of SW-Motech products, click the "Shop Now" button below:
Give our sales team a call at 888.903.4344 (Toll-Free) or 1.732.867.9995 (International) and we'll match any competitor's price.​
1 - 1 of 1 Posts
