The reason it's only sold as one assembly is because it's permanently (looks riveted?) calibrated to the throttle body at the factory. Best bet is to pick up a used throttle body assembly because unless you have a way to hook up a logging tool to the ECU and manually install the sensor when it's exactly zero degrees on the ECU you will not have accurate throttle position at low openings.
