Hello! I am considering going from 200/55 to 200/60 and would like to know if this subtle change may cause problems with the stock ECU. Thank you for your thoughts.
Thanks for sharingIf you want to have the correct TC you can't change size Tyres... Or you will need to Flash the ECU
BR
Quickshifter will also not work properly. Code Factory in Austria can help with the ECU Flash and he have a good Customer Service.
