Couple more additions to the bike.
Torx gear shaft support.
Carbon Dymag return with new hub.
Nice bikeMorning All,
Thought I'd tag my current track/race bike build from across the pond. Previous bike was a Triumph Daytona 675 2013 model used for Club 600 in a few local championships (Cracking bike). decided to upgrade to a 1000 so came across a 2017 UK base model CBR1000rr, had been written off by the previous owner on the road.
So far the bikes had:
Suspension - K-tech DDS front and rear fitted by Steve Whitear at HEL Performance. Ten-Kate steering damper brackets and K-tech damper (Toby).
Brakes - HEL calipers (Brembo Z04 pads, Motul RBF 660) and Master cylinder with dry break connections. Standard rear caliper with captive bracket - soon to have HEL thumb brake and HEL rear caliper.
Chassis - PP Tuning clip ons, Diamond racing rearsets, Evo-tech sliders, Spider captive wheel spacer, Ti fuel tank, UK race support clutch lever, alloy front and rear sub-frames, 520 racing chain.
Electronics - Ten-Kate loom, ECU and IMU relocated, BSB LHS switch gear, JMT Lithium battery. Yet to fit - Jet Prime RHS switch gear and HRC QA throttle, Honda blipper on route.
Bodywork - Hi-fibre tank and seat unit, Moto carbons carbon fairing and airtubes (Ex-Jackson Racing), pro-fibre carbon frame protectors, GB engine protection.
Performance - Full akra system, carbon bell mouths and MWR filter - 190Bhp & 85lb of torque, set up by Ben at REA Racing, silicone water hoses.
Only ridden her once at Andalucia and inital impressions are good, QS/Blipper didn't work due to switch gear issue (Hopefully resolved). But she's light, holds a tight line and good on the brakes - also matched bigger horse power bikes on the straight.
To Follow: Light weight wheels, track time and tyres!
Some on track vids to follow once the world turns the right way up again. Stay safe!
All the best Pablo View attachment 258366 View attachment 258367 View attachment 258369 View attachment 258370 View attachment 258371 View attachment 258367
Cheers afm674. She's getting there.Nice bike
Jackson Racing in the UK used to race CBR's at the TT so had one 2nd hand. Ten-Kate have some still I think.Where did you pick up the Quick action throttle?
Cheers.Nice build!
Did you do the front brake lines yourself? Can't say I've seen it run like that before?
Also, what's better about your new Rez vs the stocker in front of the rear wheel?
I've not measured the swingarm.How much longer than OEM is the KR swingarm?
Yep I noticed that, not sure why?Strange, other than your last few posts, I can't see any of your fotos.
Must be how you uploaded them, or the hosting site.Yep I noticed that, not sure why?
