1 - 6 of 6 Posts
hey guys need help
i have annoying vibration under the seat & right peg starts when i add throttle when it reach 5000 rpm even when standing
i have oil burning and when i add throttle gray smoke come out at 8000 rpm
the technician told me to change the valve seals &o rings
i also have weld on the clutch
what causes the vibration ?
Tire Wheel Crankset White Light
Wheel Tire Automotive tire Crankset Tread
Uneven power-stroke not matched between all cylinders causes vibration.
Did you squirt 2cc oil in 60% cylinder? Did it change reading?
Burnt exhaust-valve from lack of maintenance more likely than bad rings.
Reactions: h.abohadid and J D
08 cbr 1000rr
i did its 60 %
do you think bad rings causes the vibration ?
Dude you have a 08 oil burner,the burnt oil is because bad piston rings " its a known issiue even honda knows it" as far as the vibration that could be a misfire or bad burn in a cylinder because too much oil is getting into it.BTW i have a 08 and she loves to burn oil lol,i still ride and love the bike enough to not give a shit tho.I just add oil whenever it gets low and since i use rotella t4 "15 bucks for 4 quarts" im not worried about oil cost.
It's not bad rings that causes oil-burning, it's using low-grade oil. Always use full-synthetic JASO MA/MA2 oil.
Bike ran perfectly fine when leaving showroom floor. But what happens is low-grade oil burns from mile-1 and clogs rings This prevent oil from draining out holes in pistons. Then it just builds up and gets worse and worse.
Non-synthetic base oil burns form verify 1st mile. If you had used full-synthetic JASO MA/MA2 oil from mile-1, you'd never have issues with burning-oil and clogged rings. Doesn't matter if oil has exact same additives and friction-fighting abilities (which it doesn't), it's the base oil burning that's issue.
Besides, OP's problem is uneven compression. Burnt-oil and clog rings from using low-grade oil would affect all cylinders evenly, so they'd ALL have low-compression and engine would not have vibration.
Out of Rotella line, only T6 full-synthetic has JASO MA rating:
There's very large difference in anti-friction ET/EP extreme-heat/extreme-pressure additives in motor vs. moto MA oil.
1 - 6 of 6 Posts
