1 - 8 of 8 Posts
I have a SC59 abs I bought a set of wheels (used), and it turns out that the rear wheel was for ABS, and front was non-abs...
Has anyone rebuilt non-abs rims to fit abs models, if so, do you have a recipe
Are there any difference other then the mounting holes for the ABS plate/sensor?
A1 SuperMod!
There is no difference between FRONT wheel for ABS vs non-ABS. The difference is in the front rotor, because the ABS rotor has tapped holes for mounting the pulse ring.
You have the rear ABS wheel, which has tapped holes for mounting the rear pulse ring.
What is an SC 59? I’ve never gotten the hang of the model designations. What year is it? I have a non ABS 2018 that I can look at or take a picture of if it helps, but I’m thinking that is an earlier bike.
Discussion Starter · #4 ·
Sorry, i did mean the tapped holes... can you easily tap out holes for the front wheel ?
Discussion Starter · #5 ·
sc59 is 2008 until 16(?), but i have a set of ABS wheels, but bought a new pair, where one was for abs and one was not...
1 - 8 of 8 Posts
