19504-mel-000 - hose, filler neck $11...If you dropped it on the right side Im assuming this would be the a radiator part
18325-mel-d00 - protector, ex. pipe $152.89...probably factory heat shield
83150-mel-671zd - shelter set (type 4) - $626.79...sounds like it would be sumthin to do with fairings or body pieces of some sort.
The seat assy's should be the whole seat as you would take it off the bike
I dunno if this will help any but I tried, good luck with it. Also try bikebandit.com and look at their microfiche, see if you can enter a part number and search where its used if youre not sure.
