speed bleeders
13K views 29 replies 17 participants last post by  StockCarMafia
#1 ·
just got my speed bleeders in today, if i want to install them, is it just a take off old bleeders and put in new ones right? is there anything else i need to know. do i have to bleed the brakes in order to install the bleeders? im probably not going to bleed the brakes for another month or so. any help you guys. anybody have any pictures of them actually doing the job. from reading the threads it seems pretty easy, but im new at this so kinda nervous. i have the speed bleeders for clutch and front and rear brakes, if i take old bleeders out will stuff come out? or will only fluid come out if i press the clutch or brake lever?
thanks again
#3 ·
although it definitely wouldn't hurt. loosening the stock bleeders can let air in, let alone taking them off completely.
besides, the nice thing about the speed bleeders is how easy it is to bleed them. so why not?
seems somewhat redundant otherwise...
#7 ·
Has anybody had trouble with the new bleeders from cycle brakes on the group buy? I tried to install the new speed bleeder last night in the rear caliper and the diameter is too small? It will not screw in all the way down and seal? I put the stock bleeder back in and when comparing them side by side the new ones were smaller around the base with the threads? The mm of the wrench is the same? but the the threads are not big enough? ZHmmmm....
#8 ·
hey
what size did they send you? because i ran into the same issue. but i bought directly from speed bleeder. but i bought bleeders for my 07 gsxr AND 1000rr. my rear didnt work. for the rear you need SB8125L. i didnt instal the one i needed for my clutch because i used it for the rear. but check the size. but that piece probably fits your clutch or master sylinder. they sent you the wrong size
http://speedbleeder.com/Motorcycle Sizes.htm
this gives you the sizes for all bikes
#10 ·
Yes fluid will come out and YES you have to bleed your brakes after.
You will get air in the system which compresses and gives you horrible squishy brakes.
Bleeder screws have a seat that should seal before it bottoms out. It does not seal like a bolt and washer would.
#11 ·
For those with a 2008, the Front Master Cylinder and Rear Brake both use part #SB8125L (M8x1.25). The Front Brakes use part #SB7100S (M7x1.0).
So if you want to replace all of them, you will need 2 SB8125L's and 2 SB7100S's.
Thought this may help some of you since it isn't listed on the speed bleeders website.
And they get torqued to 5.9 foot pounds except the rear brake which is 4.4 foot pounds.
#12 ·
Had the same thing happen to me on my old FZ1. Called them and got very little help. Just left the stock bleeder on and moved on. Seems they're not up to speed on applications. On another note, the front bleeders work good, but if you're looking for no bubbles in the mity-vac, you'll burn through a lot of fluid before you realize it's never going to happen. At any rate, with galfers, sintered brake pads and the bleeders, I got some great brakes out of the deal. Nearly as good as my CBR's.
#14 ·
I can't for the life of me imagine why you would want to install speeders just for the sake of installing them. Are they that blingy?
And yes, bleed after ANY part of your brake system is opened.
#15 ·
I hate to ask rehash this but for the 2004 RR, is the info on the speedbleeder site correct?
Has anyone ordered these part numbers for an 04 model year and had problems.
I only ask this because h82loze mentioned only part numbers for the 2008 RR. (thanks but own an 04')
And while I am at it, they (speedbldr) lists shorts for the front and my inspection of my front calipers - are long bleeders. all the rest of the OEM bleeders on my bike are short. Anyone?
#16 ·
2007 Bleeders
since most of the parts for the 2007 and 2008 are interchangable would the 2008 part numbers list would be the same for he 2007 right??? Let me know please.... thanks.... seems like from others say the website will not be much help.. thought I would ask the community instead...
thanks
#17 · (Edited)
thanks
You could've saved yourself a lot of time by just going to the SpeedBleeders website instead of posting here and waiting for a reply.
But to answer your question, yes and no. If you check out the website, you'll know what I mean.
Edit: Actually the SpeedBleeders website is incorrect. According to Honda's parts fiche, the 07 and 08 use the same front caliper bleeder. So yes, the part numbers I listed for the 08+ are the same for 04-07.
#18 ·
I guess i really didn't waste to much time since you answered my question soon after posting... I cross referenced your part #'s and one on the website and one didnt match that is why I asked.I was more so concerned with the clutch size as well. I wasn''t being lazy... so i'm sorry if it seemed as if I was wasting your time and space on this board but it was an honest question. Thanks for the quick reply though.. much appreciated.
#24 ·
I am seeing the MC called for a SB8125 and the rear caliper is a SB8125L. I am sure it really doesn't matter but does anyone know what the difference is and why?
The L means long. The length of the bleeder is several mm longer than normal. S means short. Same deal.
So it being too long. It may hit something Inside before the thread locks. So don't assume. Get the correct one.
